Partial cut rules?
Is there a way to use say the “before end” cut rule without the speed change option?
Maybe there is a character that can be entered in the “set speed to…” box so that it uses the current cut speed - this may have already been altered by another rule and might not be known.
Just leave the feed at 100%. If another rule overlaps that rule the lowest feed rate will be used.
Excellent, knew there would be a way :slight_smile:
