Part Order
Hello, quick question, is there a way (like a line in the .ini of sheetcam). To make the software cut part to minimise slew disdance by default. When i set it and make new file it always set back to minimise tool change. Sometime i forget to change it :S
SheetCam should remember your choice. Note this setting is also saved with your job file so if you load a job file that is set to minimize tool changes, SheetCam will remember that.
i normaly load sheetcam with .exe shortcut, maybe i will make a default template to launch the software. Thx !
