Operation Load
The operation load when right clicking the mouse in the current update disappeared, it will not load saved operations.
I use that a lot it’s easier to have saved operation for difference thickness instead of I have to remember to chance speeds and lead-in’s or have a lot of tools setup
Happydane
What version of SheetCam are yo uusing? I just checked 7.0.18 and save/load operations seems to work.
7.0.18
What happens is when right clip mouse the folder I saved them in opens
but when I pick my operation, it’s not loading into the part
I tested somethings and it looks to that I have to rewrite them and save them again then they will load into part
Happydane
Was using 7.0.13 version, what version 7.0.18 seem to not load older versions operations files
Happydane
That’s odd. Could you send me a couple of your operation files.
Hope this works it will not let me add the files, “it says Invalid file extension: INSIDE MS11GA.operation”
So, I change the extension to txt, hope you can just change it back after download and it will work
Happydane
OUTSIDE MS11GA - Copy.txt (562 Bytes)
INSIDE MS11GA - Copy.txt (560 Bytes)
Ah, I see the bug was introduced in 7.0.14/7.1.15.
I’ll fix it for the next release.
Thank you
Happydane
