ajclay
1
This is a new one for me. The attached job file will show that one operation “inside offset” doesn’t want to do correctly.
I believe the drawing is good. I had the slot as a polyline and now it’s just segmented. No difference.
The layer has two cuts, both should be “inside offset” but they turn out opposite.
What do you think?
Thanks for the help and advice again.
aj
ajclay
2
My work around was to put the slot on it’s own layer and choose outside offset to make it cut on the inside.
The attached files are updated from the previous ones…
AJ
That is weird. It definitely looks like a bug in the code that determines the direction of the shape. I am looking into this now.
The next release (due out in the next few hours) uses a different method for direction detection which hopefully should be more reliable.
ajclay
5
Les, thanks for the reply. I was hoping it was on my end and not the program.
I cut my parts today without problems. Have a good day. AJ
