layers missing in dxf file
Hi,
what is wrong with the attached dxf file - not all layers are showing up in sheetcam!
thanks
C.
I see 3 layers :
Layer 0
Layer fase
Layer rastscheibe
Are this all ?
Edit: CAD program shows M3 and M5 thread but not SheetCAM
Richard
In the Drawing Options Dialog check the option ’ use points for drilling '.
Then the missing layers appear.
Richard
you don’t see a layer “aussen” or “kontur”? neither in sheetcam nor in your cad software?
I can see both layers in the layer list of the CAD but trying to show them fails so as if they would be empty.
All other layers I can activate or deactivate
Rich
I have this issue again and again. On another computer the import works without problems.
I am also missing the metric/imperial option in the scaling of the drawing import dialog - I think it is a problem of the dxf import plugin…? Am I missing any libraries…? PLEASE HELP…
C.
Do you have the correct extension *.dxf selected in the file open dialog ?
Do you have unchecked from the menu :
Options → Application Options → Annoying dialogs : Import Drawing ?
Richard
This did the trick - great! Thanks a lot!
C.
