Help with Return to Zero
I am just learning sheetcam for use with my plasma tabel and would appreciate any help you all can provide.
My machine used to cut a part and then return to 0,0. Now, after the latest sheetcam version update, it starts at 0,0, cuts the part, and stays at the end of the cut.
Is there a setting somewhere in sheetcam that I can enable that returns the torch to 0,0 after the part is cut?
Look in Options->job options->parking. You can set the X,Y parking coordinates.
