Generated G-code incomplete
Hey All,
every time I use simulation this warning message appears
Warning: WARNING: Feed rate is zero
Post processing completed with 1 warnings
and the generated g-code is in complete (no cut happen)
attached support file
what can I do
Where did you get your license? That license has been pirated and SheetCam will not longer work with it.
its from licence only or bug in program ?
The feed rate warning is a minor issue with the post processor but the lack of code is due to the license.
