Etching/marking then cutting
Hello -
I have a Langmuir system crossfire pro and using an pmx45. How could I either use the marking system to make a layer with making then cut a shape
Or
Do an etch using the EZ scribe then cut the outside shape out I am new to sheet cam, and not sure how to accomplish this
Make 2 layers in your drawing, then make a separate operation for each layer. Use the marking tool for the first operation and the plasma for the second operation.
I’m not familiar with the langmuir, so I’m not sure what tools they might have set up for you, but I assume if it has a marking option then there should be a tool already set up for this.
