double vector problem
Every time I import a drawing from either Corel or Inkscape as an svg, sheet cam sees it as two drawings and no matter what I’ve tried I can not eliminate the double problem. And when I try to set up an operation sheetcam can’t figure out which drawing to use and creates wild cut patterns. Kind of at a loss as to what to try next. I would hate to have to redraw this piece. Thanks in advance
I have this a time or two. What I have done was to open the SVG in Inkscape, select the object and go to Object, Ungroup (or . After that, click the mouse anywhere on a blank area (or De-Select) and then click again on the object and drag. If there is a duplicate, I delete one.
HTH
Paul
