Differing feeds with Sheetcam and Mach3
I’m a new user to both Sheetcam and Mach3. I was curious about duplicate info in the Sheetcam and Mach3. I am curious how the cut generation and post processing in Sheetcam is related to the cut profiles in Mach3.
If I set the feed rate in Sheetcam for say 14 guage, I’m guessing it generates the G-code that tells Mach to feed at that rate. However, if I choose a cut profile in Mach that is at a different rate, will it override the G-code.
Apologize for what may be a dumb question, but want to understand as much as possible and not just go through motions.
Figured out my own question, looks like the feed speed box in Mach is for reference only. The actual rate is controlled in Sheetcam.
