Comments in G-Code
Is it possible to put comments in the source that will be added to the G-Code? Eg Drill 5 mm, Mill 6 mm.
Open the operation and go to the ‘notes’ tab. Anything entered there will be added to the G-code as a comment.
I’m using Jet cutting and I have tried the following text in the notes tab.
Drill
// Drill
\ Drill
but none appear in the G-Code file.
It could be that the post is not set up to use notes. What post are you using?
You are correct.
Anilam and it says ‘No comments’
Do I take out the ‘No Comments’ Line to make it work ?
No. It needs some extra code in the post. How does the Anilam specify comments? Also does it allow comments on the same line as G or M-codes?
I’m not actually using Anilam, it was one that I found that uses absolute coordinates for IJ
ok, edit the post and add these lines:
function OnComment()
  post.Text(" (",commentText,")\n")
That outputs comments in brackets. If your control doesn’t recognise brackets, let me know and I’ll tell you how to change it.
