changing lead in
hi I’m having a problem finding how to change the lead in . iv done a drawing in draft sight and the holes look like the lead in is outside the hole. by that I mean not cutting from inside. advice reqd please thanks for your time. marc
Are you talking about changing the lead in position assigned within Sheetcam? That’s set up under Operations/Contour method. Inside offset, Outside offset, or No offset.
thanks again steve. when it goes across to cnc the lead ins are showing correct it just didn’t look like that in sheet cam. cheers marc.
