I am having trouble making Sheetcam 7.1.23 respect the default directories I select.
Specifically, the job file and gcode both save at the file location of the imported drawing, regardless of the selections I make in the above menu.
I haven’t had time to test it out, but check the setting in Options > Machine Options > Post Processor > Output Folder. I am betting yours is set to drawing folder. Try changing that setting.
