2 part question
First, is there a way to import multiple parts without having to go get them one at a time?
Second, is it possible to give the same operation to all the parts imported at the same time?
It’s just that i have a new Customer with lots of parts, same thickness, all different.
Thank you
Take a look at the quick load plugin (Plugins->quick load). It allows you to quickly load multiple drawings. It has an option to copy the operations from the first part or it can use a job template. To create a job template simply set up a job as normal then go to File->save job as template. A template is simply a job without any drawing data.
thank you so much!
