Good day.
I would like to pierce single points into metal, I reviewed this video > https://www.youtube.com/watch?v=pPwvYN_Hn6s
I imported a file with 2 points (use point for drill box selected)
created a new jet tool (attached)
select a drill operation with the new plasma tool (attached)
but the 2 points have S1 and S2 with a big X in the middle.(attached)
Where is my mistake and how can I fix it?
Thank you!
Plasma pierce hole not working (where is my mistake?)
- drill hole1.JPG (52.29 KiB) Viewed 251 times
- drill hole2.JPG (30.73 KiB) Viewed 251 times
- drill hole.JPG (14.19 KiB) Viewed 251 times
Re: Plasma pierce hole not working (where is my mistake?)
could be any number of things.
does your .scpost have OnDrill() customized ?
pierce delay is 0. Does the torch fire at all ?
pierce hight - cut height is only 0.020", that's going to be quick.
best if you post your .job file and .scpost file, and the .nc file you're getting. Easier to diagnose than Q & A back and forth.
my youtube channel
my youtube channel
you also have the first "shape" at 0,0 it appears. I seem to recall some obscure SC bug a few months ago when the first start point is at 0,0, and that was about the time I was customizing my OnDrill() function and testing it. Try moving the part off 0,0 origin before we go to far down this diag road.
my youtube channel
my youtube channel
Good day.
I moved the points that was not 0,0...same results.
I changed the pierce delay and nothing.
When I run it in Mach4 it just lifts the z ...cycle thru the code and there it sits
Postp attached, job file attached
- drillfail.JPG (35.26 KiB) Viewed 227 times
- Drillfail.job
- (20.17 KiB) Downloaded 24 times
- Avid CNC Mach4.scpost
- (13.81 KiB) Downloaded 26 times
Attached the tap file.
What is a NC file ?
Thank you!
What is a NC file ?
Thank you!
- pointsss.tap
- (530 Bytes) Downloaded 26 times
I've never used points for doing this before.
I've always used a circle of any size (so could be tiny circles), and then you need to ensure the "min. hole size" and "max. hole size" values are smaller and larger respectively than the circle diameter.
See if that works.
See if that works.
it appears the problem is that there is no OnDrill() function defined in the .scpost.
I'll put a basic version of OnDrill() in and see how it goes.
btw- I like the coded model to define external vars and custom options, well done. I saw one a few ago similar, or may have been the same one.
my youtube channel
my youtube channel
so I simply added this simple template example of OnDrill() and it produced gcode, however I don't know the gcode stmts for this controller so I don't know if its correct. But you can tweak the OnDrill() function if need be at this point.
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
- Drillfail.tap
- (1.39 KiB) Downloaded 22 times
- Avid CNC Mach4 w OnDrill.scpost
- (13.94 KiB) Downloaded 24 times
my youtube channel
my youtube channel
Man that updated postp did it!!!!!! Thank you! bLouChip!!!!!
I would have never figured it out.
@mancavedweller..I tried it but it did not work.
3 years messing with this machine I am almost were I want to be.
I can move on and be productive. Thanks!!!!
