G0/G1 moves
G0/G1 moves
Hi, is it possible to set the G0 feed rate separately for the XY and Z axis in Sheetcam? I didn't see such an option.
Re: G0/G1 moves
G0 is a command to move as fast as possible. As such there isn't any way to specify a feed rate. Some controllers do have a separate control that allows you to slow down the G0 speed but this isn't something the g-code has any control over.
