Maybe a Bug: Can't update operation new code snippet
jazzkramer
Post by jazzkramer »
Hi,
maybe it's me, maybe it's a bug: (version 7.1.35 linux, registered)
1) I added a G4 P10 (wait 10 seconds - for linuxCNC QTPlasmaC) before my usual code tool for Center Spot in the relative center_spot code snippet.
2) I Checked the T99 (my center spot tool) to verify that "Use Led In Settings" was checked and that the "Use Code Snippet" contains the "center_spot" code.
3) I saved the default tools
4) I reopened the job file (previously done with old center spot code) containig the job I need to modify (various nested parts)
5) I reloaded the default tools
6) I deleted the first center spot (drill) operation
7) I re-did the drill center spot operation (to the correct layer)
8) I run post processor
=> The G4 P10 is not added to the Gcode.
I tried this many times and tried closing and reopening the software, deleted gcode file, resaved job file... no way.
I think the old snipped code remains somewhere... or... I don't know.
I checked the snippet code, it's ok, it contains the G4 P10...
Is it a Bug?
Is there a way to update all my center spot operations (even re-doing the operations)...
at the moment I will edit manually, it's a simple modify but...
Thanks, Alberto
Re: Maybe a Bug: Can't update operation new code snippet
Could you send me an example job file demonstrating the issue.
jazzkramer
Yes of course
PROT_004_6mm_catenanaccio_ALL.job
(39.45 KiB) Downloaded 7 times
jazzkramer
And here the toolset if needed,
thanks.
(..and "Keep parts together" was selected in "Job options").
sheetcam_toolset.tools.zip
(938 Bytes) Downloaded 9 times
jazzkramer
Solved: it was in the postprocessor.
The postprocessor has a "drill part" in which the drill code.... So I don't know if the "snipped center_spot" code is needed anymore, but... ok, I modified the postprocessor and now it works. :)
