Hi All.
Home built machine running chinese usb motion controller and Mach3.
Problem I have.
After Drilling Operation torch performs rapid move to next Cut Operation without going to Rapid Clearance Height which I have set at 15mm.
Between Cut Operations there is no problem. Torch raises to 15mm then Rapid moves to next Operation as expected.
I have attached the gcode and post.
If anyone can help it would be much appreciated.
Thanks.
Dave
No Rapid Height after Drilling Operation
- PLASMA THC SD.scpost
- (8.57 KiB) Downloaded 362 times
- SPINDLE SPANNER.tap
- (1.54 KiB) Downloaded 397 times
Re: No Rapid Height after Drilling Operation
Anyone out there have any ideas about this?
I ran your scpost with the debugger and found that currentZ ~= safeZ test in OnRapid() was preventing the posting of Z15, notice the G00 was posted in your .tap.
btw- In that same "if" stmt, you are testing offZ as if its boolean but its not, its numeric and thus will always test TRUE unless its nil (I seem to recall that from the Lua language reference). I'm guessing that the currentZ ~= safeZ test is to prevent posting a no-motion Z value, if so, ModalNumber() takes care of that case, so the test can be removed ? I removed it, as well as offZ since if its zero then it has no effect to the endZ+offZ result. I compared before and after .tap files with this OnRapid() change and the only difference was the G00 Z15.000 vs. G00 stmt.
Perhaps an alternative to changing OnRapid() as noted above and in the posted function below, try adding [correction] currentZ = endZ in OnDrill() after returning from OnMove() and before OnPenUp() call. I didn't try this but it may solve the problem also.
In OnDrill(), consider using endZ = safeZ instead of endZ = 15.
function OnRapid()
if(endX > 1e17 and endY > 1e17) then return end
local len = math.hypot((endX + offX)-currentX , (endY + offY)-currentY)
dist = dist + len
if len < 0.001 and endZ < currentZ and endZ == pierceHeight then
return --Block the move to pierce height
post.ModalText (" G00")
post.ModalNumber (" X", (endX + offX) * scale, "0.0000")
post.ModalNumber (" Y", (endY + offY) * scale, "0.0000")
-- if(offZ and firstRef == false and currentZ ~= safeZ) then
if not firstRef then --LDC
post.ModalNumber (" " .. currentZAxis, (endZ + offZ) * scale, "0.0000")
post.Eol()
my youtube channel
my youtube channel
