GRBL Plasma w THC, Torch Touchoff, and Rotary
Re: GRBL Plasma w THC, Torch Touchoff, and Rotary
Happy to help
update version 25.7
25.1 prologue comments fixup
25.3 change default THC dynamic on/off cmd to allow continuous XY motion during state changes.
25.4 remove LdcAdcOFF flag and instead reset LdcAbsCutHeight, adj OnNewEntity() header comments.
25.5 added two machine pause cmds in Bench Test gcode so I don't use it to cut by mistake!
25.6 changed per-cut torch probe cycle from 2 probes to 1, 1/2 the time,
while maintaining same probe accuracy of +/- 0.025mm or accuracy of Z axis
25.7 added LdcPauseOnNewPart boolean option
A few versions prior I had made changes to the dynamic THC on/off gcode, moving it to Path Rules. However, 2 of the gcodes (M7 and M9) for my THC Anti-Dive Circuit (ADC) (which has the side effect of also managing the effective THC on/off state) will cause the XY motion to pause/stop during a cut, albeit just a 0.1ms of a pause/stop, the reason being that grbl is synchronizing the M7/M9 with the exact XY position in which it was placed by Path Rules. This can cause a dimple in the cut edges of the kerf, not good. I had forgotten about this motion pausing side effect.
So to fix it and have continuous XY motion while also changing THC on/off state, I changed to a similar method that I used a few versions back and cleaned up the logic a bit. This method uses spindle speed (S0 for OFF, and S1000 for ON) as the dynamic THC on/off during XY motion, in Path Rules at anytime and when Z arrives at cutHeight during a pierce. This works in a continuous motion due to grbl laser mode $32=1, and when using M4 (spindle enable signal from MCU) to fire the torch, then spindle speed (S-PWM signal from MCU) is proportionally varied automatically by grbl to the realtime XY motion speed, accounting for acceleration and deceleration. My Z THC ADC uses S-PWM to dynamically block or pass the THC Z motion signals, so below 85% of feedrate due to deceleration, the circuit blocks the THC trying to adjust Z to the plasma arc voltage deviation, and then passes the THC signals to Z when later accelerating and feedrate is > 95%. So to 'manually' or programmatically manage this circuit, I can force S-PWM to zero (S0) to always block the THC signals, or full on (S1000) to allow the circuit to function automatically again. Grbl's laser mode operation is that IF spindle speed is changed while ALSO processing a motion gcode XYZorA (called a motion block), then motion will remain continuous while spindle speed changes immediately. Lasers can respond to this instantaneous S-PWM signal change, but mechanical spindles cannot, so in $32=0 (non laser mode), then motion will pause for a spindle speed change, but again only for 0.1ms to process the Snnnn stmt, same as it does for M7/M9 stmts. If an actual mechanical spindle were being used, you'd want to insert a G04 P5 or so also to allow the spindle time to change speed. The final condition that makes the scheme work in plasma cutting with a THC and my Z ADC, is that my Proma THC SD unit is configured to delay Z motion control for 2.5 seconds, that's enough time for the pierce to occur and for grbl to move Z from PH to CH. That is why I pierce with a M4 S1000 cmd.
here's a link to the THC Z Anti-Dive Circuit schematic: https://drive.google.com/file/d/1UKgOIl ... Yx1RG/view
and grbl laser mode explained: https://github.com/gnea/grbl/wiki/Grbl-v1.1-Laser-Mode
- GRBL plasma LDC w Rotary.scpost
- v 25.7
- (41.92 KiB) Downloaded 78 times
- LDC SC tools and rules.tools.txt
- (9.62 KiB) Downloaded 80 times
my youtube channel
my youtube channel
update v26
now I remember why I retired from writing code in my day job 10 years ago
So after spending some time on the plasma table this past weekend, the modified torch probe cycle did not work out well 80% through a 130 pierce job on 16gaHR where the minor warppage of the sheetmetal combined with accumulated THC Z error caused a probe alarm, the 2mm buffer I was using in the probe cycle was not enough. Increasing the buffer distance in the single cycle probe method makes the overall cycle time about the same as it was in the double probe cycle. So I reverted back to the double probe cycle but increased the slow probe feedrate to 100mm/m instead of 50, only giving up 0.050mm of accuracy, so its still quicker and its written in a way to avoid probe error unless there is a 5mm delta from one probe cycle to the next, that's how it was previously.
There is also a fix in the OnDrill() operation when not having the RotaryPlasma plugin enabled. Thanks to Ash for finding and reporting this.
- v26
- (42.62 KiB) Downloaded 75 times
my youtube channel
my youtube channel
update v 26.2
26.1 added two custom options and external vars for OnDrill(), LdcDrillPdPct and LdcDrillChPct,
to better control and allow tuning of drill pecking rather than full piercing. See the prologue for details.
26.2 thanks to Les... added code to auto load the Rotary-plasma plugin library if necessary,
conditioned on whether or not its enabled in SC, so no need to comment out the lib stmts if not using the plugin.
* fix to THC ADC enable M7 signal timing and sequencing with Z motion.
I did some drill peck testing on 16ga with a 30A PMX30XP nozzle and found that 90% of a 0.5s pierce delay, 3.7mm PH, and 2.6mm CH (50% PH to CH adder to normal CH of 1.5) for made for about a 0.8mm dia. peck 1/2 way into the 16gaHR steel sheet, air at 72PSI. Of course PDs will vary by plasma source mfg (I'm using a PrimeWeld Cut60 with Tecmo UPM105 torch). The scpost LdcDrillPdPct default is 90%, and LdcDrillChPct default is 50% based on these tests.
- v 26.2
- (44.52 KiB) Downloaded 76 times
my youtube channel
my youtube channel
version 26.5
26.3 cleaned up msgUnit init, LdcThcONcmd timing after S0 setting, added G94 and S0 to G00 stmt,
added RTformat, changed fire cmd to M4 S0, changed LdcThcCtrl to just use M7.
26.4 added $HZ (Z homing cycle) during air supply catchup machine pause events. This is to
null out accumulation of THC Z error I continue to experience on my table.
26.5 created function DoTorchProbeCycle() to accommodate tracking/diagnosing THC Z error
- v26.5
- (46.45 KiB) Downloaded 78 times
my youtube channel
my youtube channel
update: version 28
mostly changes in gcode production to account for tuning my THC Z Anti-Dive Circuit and the Proma THC SD setting adjustments. You can read about this here: https://forum.sheetcam.com/viewtopic.php?p=31408#p31408 , and it spills over in a crosslink to plasmaspider forum.
- version 28
- (50.92 KiB) Downloaded 46 times
my youtube channel
my youtube channel
update: version 28.2
28.1 added LdcFastProbe var
28.2 added LdcProximityDist feature, supporting vars, and logic.
-- proximity distance in mm to skip a Torch Probe Cycle before piercing if current location is within proximity of a recent previous location. A value of 0 turns off the feature. Using this feature is NOT Recommended if you are also using an autonomous THC such as Proma THC SD, these units require Torch Probe Cycles on every pierce location.
- v 28.2
- (52.53 KiB) Downloaded 20 times
my youtube channel
my youtube channel
version 28.6
28.3 change double Torch Probe Cycle to single,
28.4 added feature to bypass Torch Probe Cycle if LdcTorchProbeTravel = 0.
28.5 changed OnDrill() pecking parameters.
LdcDrillPdPct -- Plasma Drill peck tuning, % of pierceDelay, 0-150
LdcDrillChPct -- Plasma Drill peck tuning, % of cutHeight, 0-250
Adjust these values from previous versions accordingly. Use Custom Option Settings window/popup to check/adjust your defaults also.
28.6 another attempt to fix entityLength in OnDrill() and later for accurate cut distance tracking
re. change to use a single torch probe cycle per cut...
inspired by @devloop to change the torch probe cycle to single cycle instead of double. Thanks @devloop.
I had tried this a couple of months ago but got the logic wrong. Hopefully it's correct this time, both of our testing seems to suggest that it is.
So anyone using this .scpost modified or as is, know that your LdcTorchProbeTravel distance will have to be recalibrated/re-measured for this version forward. Tip to do this:
*) zero the torch to the material surface
*) zero Z WCS in the digital readout of your controller
*) run command G21 G90 (metric mode and absolute distance mode)
*) run command G38.3 Z-20 F1000 (probe down up to 20 mm, the feedrate 1000mm/m is important, that's what my scpost uses), Z will stop when the probe switch is actuated.
*) note/record the Z WCS digital readout position of your controller, this is your LdcTorchProbeTravel value.
The probe command overruns the switch actuation by a distance that varies with the feedrate used during probing. As long as you use the same feedrate consistently, then the overrun will be consistent (+/-0.050mm); change the feedrate, the overrun distance changes. This has to do with the latency of the MCU as it watches for switch actuation and then decelerates Z to a stop.
- v 28.6
- (51.89 KiB) Downloaded 4 times
my youtube channel
my youtube channel
Version 28.7
Inspired by @ROTM from this recent post and drill pecking tutorial, I adjusted my .scpost accordingly. Thanks @ROTM.
https://forum.sheetcam.com/viewtopic.php?p=31626#p31626
Note though that I'm choosing for now to not change the tool or amps for plasma drilling and pecking operations. I already have logic during normal piercing to minimize the pierce hole (for open shape/path cutting reasons), which takes into account the plunge time from PH to CH; so I'm adjusting for pecking by using two custom options during Drill Operations, one to adjust pierce delay, the other to adjust pierce height, the latter being the new change from previously adjusting cut height. During Drill Ops now, cut height = pierce height and the custom option is a percentage of the normal pierce height.
During testing, I discovered my plasma cutter, PrimeWeld Cut60, will not fire with a pierce delay of 0s, rather it needs a minimum of 0.5s to at least fire. It could be that the air solenoid is worn out or failing, or it could be normal latency time for this model of plasma cutter.
- v 28.7
- (51.84 KiB) Downloaded 4 times
my youtube channel
my youtube channel
