Warning feed rate is zero
If you have any problems accessing the forum or email then ask here.
jc286006
Post by jc286006 »
Hello Everyone
I bought sheetcam in 2004 or 2005. After a 10 year break from cnc I tried to get back into it in 2016 Les was kind enough to look up my license key and sent a new copy to me. Now 7 years later I have finally gotten a new cnc partially built and am starting to practice with freecad and trying to get sheetcam to generate the g-code for drilling hold-down holes for my table it only generates 2 lines of code G21 M5 M30. After reading a post about the same issue here on the forum I re did the license key but it still outputs the same code. Its a long time since I have done any cad work or sheetcam use so it might be my newbie attempts to use it.
Thanks for any help James Coleman
Re: Warning feed rate is zero
If your license is that old it was probably for the original SheetCam. This license won't work with SheetCam TNG.
