Info about a feature into "Create Plasma Tool" dialog
shineworld
Post by shineworld »
There is a way to use the two read-only fields "Current" and "Voltage" as fields of the tool created with the button "Create Tool"?
My CNC board can control the Ampere of the plasma generator through a specific G-Code so this field is very interesting.
The CNC board uses an analogic input to manage THC and also Voltage parameter is useful.
I've already added two custom tool parameters:
--- SHEECAM CUSTOM TOOL PARAMETERS
post.DefineCustomToolParam("PlasmaTool","Generator Ampere","cutAmpere",sc.unit0DECPLACE, 0, 0, 500)
post.DefineCustomToolParam("PlasmaTool","THC Cut Volts","cutVolts",sc.unit0DECPLACE, 0, 0, 500)
but obviously when I create a new tool with "Create Plasma Tool" these fields are set to 0.
There is a lua script and info on how to extend behaviour ?
Thank you for suggestions.
djreiswig
Re: Info about a feature into "Create Plasma Tool" dialog
Post by djreiswig »
In your tool parameter declaration one of the two zeros is the default value. I don't recall which one it is but it should be in the manual. I'm not sure if that is what you're looking for or not.
shineworld
Ok, I can also add a default value in "cutAmpere" & "cutVolts" custom tool parameters but that I would
like to know is if it is possible, in PlasmaTool.lua, to get database (csv) Current and Voltage fields and place
programmatically the values in the custom parameters during "Create Tool" (onCreate) event.
