Trayectory problems
Trayectory problems
Hello.
The trajectories of the simulation do not follow the cutting profile of the drawing.
Debug: version 7.1.32
Assert failure in function wxCSConv::wxCSConv (C:\wx-3.0\wxWidgets\src\common\strconv.cpp:2870). invalid encoding value in wxCSConv ctor ("Assert failure")
I have inviate an email with support file.
With a simulator the generated gcode seems ok, but I'm afraid to send it to work.
It only does this when using the manually interrupt nested drawings function.
Re: Trayectory problems
Sorry, wrong section
Do you have simulation set to the correct machine type? In simulation click on the setup button and check the machine type is correct. For instance if you are plasma cutting it should be set to 'Jet'.
It's set to jet, but the problem persists.
I tried to do the single step simulation and it's fine.
Another problem I encountered is inside the support zip file the gcode that it inserts is not the one I'm simulating, but a previous one from a previous job.
The simulation in the car is ok... I try to cut it?
I'm a bit late but if it simulates correctly it should cut correctly.
No, it doesn't simulate correctly but it cuts correctly.
Did you email me the support file? I did not receive it.
Yes, 2 email with a file support. At sales@ ... and problems@forum...
I resent another email with everything at sales@sheetcam.com.
That one got through. I ran simulation on your job file and the tool followed the path exactly. What exactly does it do when you run simulation?
