Hi there
I’m having problems with the post processor, I have a Burny 2.5 with a 1200 replicator on an ESAB table. The only way I can get it to work any sense is to use the Burny 2.5 and 3 post processor absolute, I then have to spin the work in the Burny by 270 degrees. If I use the incrimental processor either with swapped axis or normal, it moves holes to different positions and instead of leading in from the middle of the holes it leads in from the outside. Any help would be much appreciated
Thanks Paul.
Post processor problems Burny 2.5
Re: Post processor problems Burny 2.5
Where is the origin (X0, y0) on your table?
I have the origin at the left hand bottom corner.
Do both SheetCam and the machine have the origin in the same place?
Hi there
Yes they do.
Yes they do.
Sorry for the delay in getting back to you. If the origins match the cuts should match.
The graphics display in SheetCam assumes you are stood at the machine with the X axis left-right and the Y axis away from you.
