Plunge Safety Clearance
DynMetalworks
Post by DynMetalworks »
I'm running a ESS & Warp Runner on my plasma table. In sheetcam, I have the rapid clearance in job options set to 2" to avoid tip ups. However, this makes probes take a long time on every cut.
On a older table I had CandCNC controller and in Sheetcam I could set the Safety Clearance height and Plunge Safety Clearance height. The torch would rapid down to the Plunge Safety height then slow to probe the plate. I've tried this with the WarpRunner V5 post, but it appears the Plunge Safety height does not do anything. Is there some other way to set this?
WarpRunner Mach4 v005.scpost
(13.56 KiB) Downloaded 663 times
