Scanything (CNCRemote) + Linuxcnc Build
Re: Scanything (CNCRemote) + Linuxcnc Build
I can replicate the fault here but I can't currently find a solution. I changed run-scanything to keep any existing LD_LIBRARY_PATH paths:
#!/bin/sh
BASEDIR=`readlink -f "$0"`
BASEDIR=`dirname "$BASEDIR"`
cd "$BASEDIR"
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$BASEDIR/lib
echo ld path = $LD_LIBRARY_PATH
"./scanything"
I can see that $LD_LIBRARY_PATH contains both Scanything's lib directory and LinuxCNC's lib directory but ld still can't find libnml.so.0, even though that file is clearly in LinuxCNC's lib directory.
As you have probably guessed by now I haven't done much testing using a rip-environment.
robertspark
Post by robertspark »
I can compile and install linuxcnc as debs (that is what I normally do, I update the git clone via git pull and the compile and install the debs)
robertspark
whhhhooooo
it works!
20:15:52: Started
20:15:52: Loading plugins
20:15:52: LinuxCNC server is running
20:16:00: Machine running and homed
20:16:06: Camera 'MICROSCOPE 2' found
20:16:06: Camera opened and running...
https://www.supereyes-store.com/collect ... led-tripod
steady 30 fps and a moderate cpu load ~ 20 % up to about 50% max if i really shake it about (not fixed it to the machine yet just hanging loose)
but it works!!!!!
thanks les
robertspark
That's good news. The X axis coordinate looks a bit odd. Is the machine homed?
robertspark
no it wasn't homed at the time but I can now play with it and get some part tracing done.
it was on a 3 axis router with a shared Y, so 4 joints hence I thought it was picking up odd numbers as it was probably looking at the 4x joints for the 3x axis unit it was homed.
robertspark
Les Newell wrote: Mon Mar 21, 2022 3:57 pm Are you running 32 bit or 64 bit Linux? What version of Scanything are you using?
If you are using a 64 bit distro, try this version of Scanything www.sheetcam.com/Download/Scanything_se ... .23-64.bin
what happened to this file?
any chance of adding it to the scanything downloads site please?
https://www.sheetcam.com/Scanything/downloads
caretech
Post by caretech »
Robertspark: this link still works --
The link in the post above prefixed forum.sheetcam.com, making the URL invalid.
