Moving Start point
Moving Start point
Is there a way to Move the start point from one side of the cut line to the other. For instance when doing an inside or online cut the pierce will be on the inside. I want to move it to the opposite side so my pierce will not be in the part and allow a little extra clearance for a slot. I hope that makes sense. Thanks
Re: Moving Start point
if you change the cut to outside offset, and edit the start points you can move them
You can't change the leadin side with outside or inside offset. With no offset you can change teh side. Switch to start point mode, right-click on the start point and select 'Reverse cut side'.
I just did that and it worked perfect. That is just what I wanted. This will come in handy. Thanks for the help.
