Warning Feed rate is zreo in Sheetcam
If you have any problems accessing the forum or email then ask here.
Lucas78
Post by Lucas78 »
Hi guys. This is my first year working with CNC plasma cutter machines using Sheetcam TNG without any issue. Just a couple of days ago when I try to PP or SIM, The program doesn´t work, No SIMs and not code generated (just a few lines M5, M30 and some other few lines). The error say " Feed rate is zero". Do You know how fix this issue or if it is a license issue?
Re: Warning Feed rate is zreo in Sheetcam
That sounds like a license issue. Try reinstalling the license. If that does not help give me the license serial number. You can find it in Help->about.
kb24la
Post by kb24la »
I am having the same issue, can someone help?
djreiswig
Post by djreiswig »
Try emailing les@sheetcam.com. maybe send him your license file.
