tool number
cdedwards
tool number
Post by cdedwards »
Seems you can't search for "tool number" so I need to ask.
I'm using linuxcnc with plasmac. I can create a materials file from the tool table of sheetcam. It's a good materials file for sheetcam.
Now how do I get sheetcam to output that into a M190 P# in the gcode? I edited the post processer and setup the materialFile = true in there. I also added the following snippet to OnInit() as it doesn't appear to call the OnToolChange() at all. Material is always 0 therefore it never runs this.
post.Text (" (Material: ", material, ")\n")
if(material > 0 and materialFile) then
post.Text(" M190 P", material, "\n")
post.Text(" M66 P3 L3 Q1\n")
I added this snippet into the OnPenDown() function just to see if I added to the wrong place. Basically the tool number is not being output or material is not being set at all by looking at the tool number and making material equal to it
N0010 (Filename: makerCARVER Gantry Plates v1.ngc)
N0020 (Post processor: LinuxCNC PlasmaC.scpost)
N0030 (Date: 20/02/2021)
N0040 G21 (Units: Metric)
N0050 G40 G64 P0.005 G90
N0060 F1 S1
N0070 (Material: 0)
N0080 (Part: makerCARVER Gantry Plates v1)
N0090 (Operation: No Offset, 0, 45 Amp 1/4"  Mild Steel)
N0100 G00 X72.7981 Y83.2771
N0110 M65P2 (THC On)
N0120 M65P2 (THC On)
N0130 (Material: 0)
N0140 (Material: 0)
N0150 M03 $0 S1
N0160 G04 P0.6
N0170 G03 X73.8404 Y84.7316 I-1.4111 J2.1119 F[#<_hal[plasmac.cut-feed-rate]> *
cdedwards
Re: tool number
Post by cdedwards »
I've narrowed it down to the
post.DefineCustomToolParam("PlasmaTool", "Material", "material", sc.unit0DECPLACE, 0,0,1e17)
This doesn't appear to work at all. If I initalize material to 27 instead of 0 it will load the material as it should. the aforementioned line does nothing and does not set the material to a value at all.
Re: tool number
The custom parameter variable won't be set until the tool change so your code needs to be in OnToolChange.
cdedwards
Re: tool number
Post by cdedwards »
I'm using the default linuxcnc PlasmaC post file and
is placed just after the start of the post processor file. linuxcnc plasma post doesn't even have a OnToolChange() function.
from the plasmaC post we have the following, which of course does not work.
function OnToolChange()
curFeed = feedRate
Re: tool number
I don't see anything obviously wrong there. Could you send me the whole post so I can take a look.
cdedwards
Re: tool number
Post by cdedwards »
Here's the unedited post file
------ Configuration options ------
-- Set this to true if you have the multi-tool option enabled in PlasmaC.
-- If not set it to false
multiTool = false
-- Set this to true if you are using a material file.
-- See http://linuxcnc.org/docs/devel/html/plasma/plasmac-user-guide.html#material-file
-- Set it to false otherwise
materialFile = true
-- Set this to true if you want SheetCam to control the feed rate.
-- NOTE if you use rules to change the feed rate, these changes will affect the
-- feed rate even if useFeed is false
useFeed = true
---- End of configuration options ------
if materialFile then
function OnAbout(event)
   ctrl = event:GetTextCtrl()
   ctrl:AppendText("LinuxCNC plasma post processor\n")
   ctrl:AppendText("\n")
   ctrl:AppendText("Incremental IJ\n")
   ctrl:AppendText("Does not use Z axis")
   ctrl:AppendText("NOTE: These parameters in SheetCam have no effect:")
   ctrl:AppendText("Feed rate (optional - see config options)")
   ctrl:AppendText("Pierce delay")
   ctrl:AppendText("Pierce height")
   ctrl:AppendText("Plunge rate")
   ctrl:AppendText("Cut height")
function OnInit()
   post.SetCommentChars ("()", "[]")  --make sure ( and ) characters do not appear in system text
   if(scale == metric) then
   else
   post.Text (" G40 G90\n F1 S1\n")
   material = 0
   curFeed = 1;
   curScale = -1
function OnNewLine()
   post.Text ("N")
   lineNumber = lineNumber + 10
function DoFeed()
   if useFeed then
      post.ModalNumber (" F", feedRate * scale, "0.###")
   else
      local scale = feedRate / curFeed
      if scale ~= curScale then
         curScale = scale
         post.Text(" F[#<_hal[plasmac.cut-feed-rate]> * ")
         post.Number(scale,"0.###")
         post.Text("]")
function OnFinish()
   post.Text (" M05 M30\n")
function OnRapid()
   if(math.hypot (endX - currentX, endY - currentY) < 0.001) then return end
   post.ModalText (" G00")
   post.Eol()
function OnMove()
   post.ModalText (" G01")
   DoFeed()
   post.Eol()
function OnArc()
   if(arcAngle <0) then
      post.ModalText (" G03")
   else
      post.ModalText (" G02")
   post.NonModalNumber (" X", endX * scale, "0.0000")
   post.NonModalNumber (" Y", endY * scale, "0.0000")
   post.Text (" I")
   post.Text (" J")
   DoFeed()
   post.Eol()
function OnPenDown()
--[[   if (preheat > 0.001) then
      post.Text ("\n G04 P")
      post.Number (preheat,"0.###")
      post.Eol()
   post.ModalNumber (" Z", pierceHeight * scale, "0.0000")]]
   post.Text (" M03")
   if(multiTool) then
      if(toolClass == "ScriberTool") then
         post.Text(" $1 S1")
      else
         post.Text(" $0 S1")
   post.Eol()
   if (pierceDelay > 0.001) then
      post.Text (" G04 P")
      post.Number (pierceDelay,"0.###")
      post.Eol()
function OnPenUp()
   post.Text (" M05\n")
   if (endDelay > 0) then
      post.Eol()
function OnNewOperation()
   post.Text (" (Operation: ", operationName, ")\n")
function OnComment()
  post.Text(" (",commentText,")\n")
function OnNewPart()
   post.Text(" (Part: ",partName,")\n");
   curFeed = feedRate
function OnDrill()
   OnRapid()
   if(multiTool and toolClass ~= "ScriberTool") then
      post.Text(" M3 $2 S1\n")
   else
      OnPenDown()
      OnPenUp()
Re: tool number
I just tested the post here and it does what it should. I'm seeing M190 P10 when I set the material to 10.
Try restarting SheetCam after selecting the post.
cdedwards
Re: tool number
Post by cdedwards »
ok updated to .26, restarted and reran the file using the PlasmaC post which I edited to change materialsFile = true. No M190 in the file at all.
Restarted sheetcam made sure PlasmaC post was chosen and redid everything. Attached is the gcode file.
makerCARVER Gantry Plates v1.txt
gcode file from linuxcnc PlasmaC post.
(7.17 KiB) Downloaded 605 times
makerCARVER Gantry Plates v1.dxf
DXF of project
(30.35 KiB) Downloaded 569 times
Re: tool number
Huh. That's odd. Could you give me the job file (File->save job) with everything set up ready to post process.
I'll give it a go here and see if I can figure out what is going on.
cdedwards
Re: tool number
Post by cdedwards »
Here is the job file as requested
NoM190job.job
(64.11 KiB) Downloaded 850 times
Re: tool number
I just tested it and it works as expected. Note that material defaults to 0 so you need to set the material to a number greater than 0 for the M190 etc to be output.
cdedwards
Re: tool number
Post by cdedwards »
thanks. that was the issue actually. I was expecting it to change based on tool number. material number was set to 0 in all tools. Maybe a warning in the post about this would be an idea or the option to use the tool number instead of a material number. In plasmaC we seem to be using the tool instead of a material number to setup for the M190 needed.
