Hey Les,
Does a plugin for nestfab exist? I see the one on the sheetcam website for mynesting, and there is reference to a nestfab plugin there and in the forum, but i dont see it anywhere.
Plugin for NestFab
- Contact:
- Contact:
Re: Plugin for NestFab
Just wondering if you missed this post too Les
Sorry, you can get it from here https://www.sheetcam.com/plugins
- Contact:
I'm sorry, but i still do not see a plugin that works with NestFab on there. There is the plugin that works for MyNesting, but NestFab uses a different file extension and will not work.
That plugin should work with both. I can't remember what happens if you have both Nestfab and MyNesting installed at the same time.
- Contact:
I only have Nestfab installed. When i try to export a part to nesting, SheetCAM crashes and closes. If I try to import a nest from Nestfab, i cant even locate the file because the file extensions are different.
