Fanuc post processor & cut depth problems
Re: Fanuc post processor & cut depth problems
If you look at the first file I attached (05003.txt) line N200 GOTO210 is used to skip over said amount of holes. For example if for some reason we lose power at the shop while drilling line N6110 when start back up I can change the GOTO number to that line and the machine will go to that hole and start.
What happens if you have multiple drilling operations, should each drilling operation have it's own goto? What about for other operations?
I understand what you mean for other operations or jobs but this post processor will only be for this type of job. 90% of the drilling we will be doing is this type of tubesheets only bigger or smaller in diameter with more or less holes. I can add the GOTO manually if needed. Just trying to take out human error if possible when someone else has to do it other than me.
I'm trying to keep the post as generic as possible so the it can be used by others. Give this a try.
- Fanuc mill with canned drilling.scpost
- (7.12 KiB) Downloaded 86 times
Works great!!!! Thanks for all your help Les!!!
