Hello to all,
Is there a way to edit the post so it rapids to the first x,y position of an operation before it rapids to the safe Z height?
I am using the dev version now. Here is the modified fanuc post I use. Thanks for any response.
Rapid to cut position before rapid to safe z postion
- Fanuc.scpost
- (6.44 KiB) Downloaded 78 times
Re: Rapid to cut position before rapid to safe z postion
Go to Options->job options->tool change and turn on 'No move to safe Z after tool change'. That should do what you want.
