Hi everyone,
My plasma machine programs the kerf width on the machine interface and only requires a toolpath be generated by SheetCAM. I need to modify the post to allow for this, but i am unable to figure out how. It is a Burny Phantom2. I know the G-code i need to write is G41 for inside offsets and G42 for outside offsets, but i am not able to find a SheetCAM variable to associate that with.
I tried the code below, but "toolOffset" always seems to return 0.0000. I though it would be either a positive or negative number, but it does not appear to be what i was looking for. Can anyone offer any advice? Or any method to accomplish this?
-- post.NonModalNumber ("(Offset ", toolOffset, "0.000##")
-- post.Text(")")
-- post.Eol()
-- if (toolOffset > 0) then
-- post.Text("G41")
-- elseif (toolOffset < 0) then
-- post.Text("G42")
-- else post.Text("G40")
-- end
-- post.Eol()
David
toolpath offset in post processor
- Contact:
- Contact:
Re: toolpath offset in post processor
I have figured out a method to accomplish this using the function OnOffsetLeft, OnOffsetRight, etc. if anyone runs into this again.
That is experimental so I can't guarantee it will work. Leadins in particular may behave oddly.
- Contact:
Thank you for the warning Les. I will be sure to continue checking behind it to make sure it does as intended. So far it has worked without any issues.
I can say that the offset seems to be applied after the PenDown function. For my machine, the offset needs to happen before the PenDown command which is used to start the arc. I found a way to code around that and have the post write the offset first, but it is not fool-proof.
