I currently have a rather complicated Milling file with about 20 layers.
I export the DXF file from Rhino 5 and import into Sheetcam.
The layer order is no longer the same as Rhinos after import into Sheetcam. The main problem definitely comes from Rhino export. As far as I can see in the DXF with a file editor, the layers are also there not in the desired order.
This is annoying but would still be ok if I could arrange the layer order in Sheetcam again. Is there an option hidden somewhere? In the layer tool, I can only disable individual layers.
Currently, the assignment of the individual operations is absolutely confusing.
greetings
Jan
Modify Layer Order
Re: Modify Layer Order
I don't think you'll need to re-order the layers. Let me explain.
When you create an operation, you select the layer to work with. So if you have say 3 layers, you create 3 separate operations, 1 for each layer.
THEN you can drag the operations up or down to change the order in which they are done.
Just double checked and it works perfect.
Keith.
Keith.
That`s how I´ve done this in the past, but with 20 or 30 Operations this is not very comfortable and clear.
