After importing drawing, setting up operation and running simulation everything runs fine, save job, save part, run post processor and save g/code.close job and save, open same job and get error message (NO HOLES WERE
FOUND), this as happened pretty regular over the last 3 years.
Problem is it means starting all over again importing drawing etc., and also when opening a part for Nesting, there are no Drill Holes, as any one found a fix for this Bug.
No holes were found
No holes were found
- Capture.PNG (32.72 KiB) Viewed 961 times
Re: No holes were found
Thanks for the file you sent me. I can see the fault here and am working on fixing it. I can't believe how long this bug has been there It slipped though my net because it only appears on the release versions. It does not show up on my debug versions.
Sorry to bump old thread I had this problem the 1 time I tried and gave up on it....for plasma process to centerpunch dill holes....is this issue fixed? I'm running the newest unstable release. Thank you
Yes it should be fixed. Let me know if you have any issues.
