GRBL Post processor for Sheetcam
Re: GRBL Post processor for Sheetcam
Ok great thanks again Les now i can purchase the full ver knowing it will work.
Sorry for the reply on this "old" thread.
I found the GRBL THC with scriber.scpost very usefull for my cnc plasma. I'm using the openbuilds blackbox controller.
It reads the grbl code with no problem, but i find an error when cutting:
error 26: A G-code command implicitly or explicitly requires XYZ axis words in the block, but none were detected. [N0130 G02 10.0000 J-0.7500 F2500.0].
It seems like cutting smal holes is a problem, moving along straight lines is not..
Any suggestions?
Any suggestions?
Give this a try. To install this post, save the attachment to any convenient folder on your computer then run SheetCam and go to Options->machine->post processor. Click on the 'Import post' button. Using the box that appears, navigate to your post and open it. Go back to Options->machine->post processor and make sure your post is selected.
- GRBL THC with scriber.scpost
- (7.73 KiB) Downloaded 279 times
