I run SheetCam with Mach3 and a THC301 made by Texas MicroCircuits. Use a machine torch with a scriber plate marker. Thermal Dynamics A60.
Attached is a text file of the Post Processor file I am using.
This Post Processor is "Designed for use with Mach3 and CandCNC MP1000-THC and Floating head Touch-n-Go\n"
Has anyone made a Post Processor file specifically for the THC301?
The reason I want to know is that after a lot of troubleshooting with "Arc OK" issues, I'm hoping find an optimum configuration for my machine. I can cut a part or two without much trouble. But when I have a nest of parts or a part with multiple pierces, my machine will stop upon making a new pierce. The torch remains on but the machine won't advance, no "Arc OK" signal.
Running SheetCam V 4.0.10 on my machine. (I've looked at version 6.0.23 and it still did not have a PP for THC301)
Should I continue down this path or is the Post Processor file a non-issue for my "Arc OK" issues?
Thanks for reading,
Dan
No Post Processor for THC301?
- DF Post Processor Backup Original.txt
- (5.92 KiB) Downloaded 163 times
