Sheetcam Crashes
gsfantos
Sheetcam Crashes
Post by gsfantos »
Hi there,
everytime I am trying to import the specfific drawing once I am trying to create a new jet cutting operation, sheetcam crashes and shuts down!
Anyone has any idea what am I doing wrong?
Thanks in advance
HS-UT-18-1001.dxf
(353.39 KiB) Downloaded 97 times
WyoGreen
Post by WyoGreen »
I opened your file with no problems, and set up an inside and outside jet cutting operation with no problems either. Maybe your Sheetcam program is corrupted and needs to be reloaded.
dennisshaw
Post by dennisshaw »
It is possible some one as stole your License, check with Les. are try it with another dxf that previously worked.
HS-UT-18-1001.svg
(40.95 KiB) Downloaded 77 times
This shouldn't be a license issue. It is more likely a graphics problem. Try the development version of SheetCam as it uses a slightly different method of drawing the graphics.
gsfantos
Post by gsfantos »
Hi there,
I am already using the development version of Sheetcam (with a proper licence). The problem appears only with the specific dxf file. If I remove some parts from the file then it works fine.
Any other suggestions?
Thanks in advance for your time
