Cuts not complete
Cuts not complete
I've run into a problem with some of my cuts not completing, such as the inside of a zero, or the torch may start moving and making the motions of the cut but the torch doesn't fire until after it's moving causing the cut to be incomplete. I'm using Qcad, Sheetcam, and Mach3, using the Mach3 plasma post processor. Where should I look?
