I have the PlanetCNC USB-mk3 controler and witch post procesor is compatible with this controler without manualy modifying the G code.
Is there someone who uses the PlanetCNC USB controler.
Post procesor problem
In SheetCam go to Options->machine->post processor and click on the 'Edit post' button. Look for this piece of code:
and change it to
That should do what you want.
function Reference()
firstRef = false
post.Text(seekCode .. "\n")
post.ModalText(" G92 Z")
post.Number(-switchOffset * scale, "0.0###")
post.Eol()
post.CancelModalNumbers()
firstRef = false
post.Eol()
