Hello,
I am a new user to Sheetcam and have the licensed version (I am told) which came along with my purchases from CandCNC. The first issue that I am having is when I open up the program on the main screen, the left column that contains, “Toolsâ€, “Partsâ€, “Operations†& “Layersâ€â€ is truncated to the left as you can see in the attached photo. When I hover the mouse over the vertical line, I don’t get the usual <-> symbol in order to be able to drag it to the right or left so I am unable to see the full content. If anyone has any advise here, I would appreciate it.
Thank you,
Truncated Main Page
Truncated Main Page
- Sheet Cam Screen.jpg (633.56 KiB) Viewed 1305 times
I've studied your photos, and I see you're running Sheetcam on Xubuntu. But that's the only thing I've been able to figure out so far. I only mention that you're having this problem with the Linux version of Sheetcam, as that may help someone else help you. Your screen is considerably different looking than mine, but I don't have a clue as to why. Maybe an option? Are you running the latest Linux version of Sheetcam (6.1.40)?
Sorry not to be more help, Steve
