Help! No code generated
Robertcarterknives
Post by Robertcarterknives »
I've had sheetcam for 5-6 months now. Was running some parts yesterday with no issues. Change out part. Go over to my computer to import a new drawing. Cam everything as always. Tried to post and sheet cam was only sending base command codes to the machine. Also have a no federate warning when I try to simulate. Any help would be appreciated.
Robert
rrossetti
Post by rrossetti »
hi are you talking about mach3?
i have seen this issue before on mach3
open gcode make sure file types are tap and not all files
that should cure it
This is my fault. I have sent you a new license which should sort out the problem.
Robertcarterknives
I received the new license agreement and I am back up and running as of a few days ago. Thank you Les!
