Warning: feed rate is zero
Posted: Tue May 30, 2017 4:43 pm
by dennisshaw
I have used Sheetcam for over 12 months with no problems, from this afternoon when I loaded various parts and run Simulation, all I get is (Warning: feed rate is zero) I have tried re-loading Sheetcam, checked my options etc., nothing seems to work.
Regards.
Posted: Tue May 30, 2017 5:34 pm
A number of SheetCam licenses have been copied and no longer work. This sounds like what has happened to you. If you send me your license ID (Look in Help->about) in a PM I'll check it for you.
Same Problem
Posted: Tue May 30, 2017 9:34 pm
by DUNK7050
Hi Les
This is the same problem that i have.
I sent my licence number late this afternoon using the SheetCam "Create a Support File" option.
I will send it again via PM
Hope we can get this sorted out asap
Regards
Dunk
