Maybe someone could help me I lay .5 flat bar side by side then cut across the X axes making squares but at each seam there is a little tab that is still connected I have been told to use action points but when I try the machine slows down at the first triangle but does not speed up again why are there two triangles at the seam do I want one before and one after ? do I want two before and two after maybe there is some writings about this or video ? I draw in auto cad then Sheet cam then mach 3 HTPM 85
Little Bit
Connecting tabs
