Question about operation
Posted: Sat Apr 15, 2017 10:01 pm
by Black70
Trying to test out Sheetcam with my Tracker CNC. I am using Corel x7 for drawing and made an L bracket to play with. I did the simulation and everything is good to go. Last thing I did was to run the post processor. It's saving it and then says post completed. Is it suppose to start cutting then? What am I suppose to press to start to cut? When it does cut, how can I stop it if something goes wrong. Tks
Pat
Posted: Sat Apr 15, 2017 10:44 pm
by WyoGreen
The post in Sheetcam writes a G-code file. Then you load your g-code file into your Tracker controller. The cut is started from there.
Posted: Mon Apr 17, 2017 11:18 pm
by Black70
Can you or can't u cut something in the trial version. I know it's for a limited amount of g-code lines but I wanted to cut this to play with the software. Tks
Posted: Tue Apr 18, 2017 12:32 am
by jim1108
Yes you can, up to the trial version limit of lines of code.
Posted: Tue Apr 18, 2017 12:58 am
by Black70
Mr. Wyogreen mentionned to load the saved processed file into my controller and cut with it. I tried to find what am I suppose to open as a software for the controller but a Tracker comes with only the Command n cut software. If I take it to open the new G-code.plt file it still cuts the same as if I didn't use Sheetcam at all. Anybody knows how I can open or start my controller to work and cut the Sheetcam G-code file. I guess that is when the guys who have Sheetcam and Mach3. Mach3 is the software used to make the plasma cut. So I draw with corel x7, I create g-code file with Sheetcam, now do I need another software to make the plasma start to cut? Tks
Posted: Wed Apr 19, 2017 12:53 am
by WyoGreen
Pat,
I can't answer your question, but if you ask it over on PlasmaSpider.com, I'll bet there are some Tracker owners over there that can answer it.
