Double cutting
rocketheater.com
Double cutting
Post by rocketheater.com »
I've been using draftsight to draw my files. I exported the files into a DXF and loaded them into sheetcam. I double checked the drawing and there are no flaws or errors in the lines, nodes, tangents, or anything else. However, the cam wants to cut all the lines twice in opposite directions. How do I fix this?
ajclay
Post by ajclay »
You've got me wondering on this problem. Post your dxf file so we all can take a look. 2d Draftsite is a great "free" drawing program....
rocketheater.com
Double Cutting, DXF File
Attached below is the DXF. I got it working by just restarting the program. I have no idea what was wrong. Basically it was wanting to cut the holes to be both inside and outside the edge of the lines.
Heavy Duty Burn Grate.dxf
(23.83 KiB) Downloaded 101 times
