Everything working fine unil cutting circles Sheetcam simulator running fine and then running tap file in Mach 3
Seems like Mach 3 is not recodnizing some of the code
Will add postproceesor file and tap file
Help
Plsmatech
Sheetcam 6.0.23 and Mach 3
- Patrick 5 MP1000-THC-Fan on piercecount.post
- (4.86 KiB) Downloaded 81 times
- gasket25.tap
- (2.29 KiB) Downloaded 82 times
See photos
Please see photographs
- perfect in Sheetcam
- Gasket01.jpg (26.26 KiB) Viewed 1359 times
- Gasket02.jpg (87.6 KiB) Viewed 1359 times
- No good in Mach 3
- Gasket03.jpg (19.19 KiB) Viewed 1359 times
I'd try changing your Sheetcam job. First, I'd move the outside circle to it's own layer. Then I'd set up an operation to cut the layer the 5 inside holes are on as an inside offset cut. Next I'd set up an operation to cut the layer the outside circle is on as an outside offset cut. I think that will clear up the problem you are having.
