Bug with Code Snippits
Posted: Thu Jan 19, 2017 3:01 pm
There appears to be a bug with code snippets.. Both in the released version and the developmental version.
If you create a part file with a code snippet under cutting operations. Then later try to remove the code snippet by selecting "None" on the Cutting operations screen. It does not remove the code snippet from the part.
It will show up as "None" in the cutting operation. But when posting it the code snippet will show up in the gcode
Attached is a sample job file.
