Hi all,
Just signed up today.
I can’t find a tutorial on Sheetcam that explains how to add start points. On occasion Sheetcan will generate a tap file lacking 1 or 2 numbered start point and as you know, Mach 3 is subject cut then after the outside cut. Likely something simple but thus far it has avoided me.
Moccasin
Missing numbered start points
You cannot add start points. Every line or contour that can be cut will have a start point. If some part of your drawing isn't being cut it is either on the wrong layer or it is too small for the tool to fit. If you send me your job file (File->save job) with everything set up ready to post process I will take a look and see what is going on.
