Pakko
Posts: 15 Joined: Sun Dec 04, 2016 6:17 pm
Post
by Pakko » Sun Dec 11, 2016 5:33 pm
ok, I turned on the thc just after m03 but then it stops all motion and does not continue the program...
Posts: 3665 Joined: Thu May 11, 2006 8:12 pm
Post
by Les Newell » Mon Dec 12, 2016 10:44 am
Pakko wrote: maybe I should ask this question in the mach3 forum, but I think the knowledge is here too.
Does the thc on/off button work when the "Allow thc up/down control even if not in thc mode" is checked? If I want to turn it off directly after m05
That is odd. Are you sure your 'arc OK' signal is working correctly?
Pakko
Post
by Pakko » Mon Dec 12, 2016 5:13 pm
I went out to the plasma and tested, and the arc ok sign does not come on in mach3 when the torch is lit. So now I have some cable/board investigation to do. Thanks Les
