Posted: Fri Dec 23, 2016 3:56 pm
I would suggest alway using loop sharp corners. It may be worth looking through the manual for your controller to see if theer are any settings related to small arcs.
In g-code circles are specified with an arc where the start and end are in the same place. Most controls have a tolerance where start and end points very close together are considered to be in the same place. It is possible this is the issue with your controller. It is possible this can be configured in some parameter on the control. Have a look through the manual to see if this is possible.
